Good Morning!
TTRW and JDI000- Thanks for the welcome to this forum.  It is a good sign when there are passionate users who will dedicate some valuable time to help a newbie over a hump - it speaks well for the software product and says volumes about the quality of people who are the users.
So, to answer JDI000's reply, I am trying to move two solid objects by dragging them in a Top, Front or Right view.  My snaps are the default, and I snap to grid as a rule to place the objects.  For "grins", I have attached a very simple file with the two solids - one a tall extruded "C" ring, and the other a arc-wise contoured tall extruded rectangle.  The rectangle hang over the c-ring by a 1mm at the edges to avoid a bisected edge or face at a quadrant point or endpoint on the c-ring - this was essential to successfully blend the edges completely around the c-ring later.
If I nudge the tall rectangle around in the Front and Right views, and them nudge the c-ring around in the top view, I frequently close in on the desired alignment fairly quickly.  If I nudge one part or the other exclusively, I can go in circles for quite a time...
Well, that's it for now on this problem.  I assume that Tim is the VP at Punch who will collect problems and issues and address them as the company is able with maintenance releases.  Tim - this is a "groaner" of a problem.  On the whole, though, this is tremendous software.
Again, if there is something that I can do to work around this, it would be valuable for me to know!
Thanks again for your time.
Brian
 Intersection Problem.vc3
(35kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
