1. Tried playing around with the tolerances with fractions.  Having some trouble with this.  It doesn't like placing fraction tolerances right after I change the text size.
It seems to change the dimension style from fractions to one of the other styles every time I change the font size.
Would like the ability to add tolerances to multiple dimensions at a time.
2. Text in the dimensions likes to change size in the viewports when changing the dimension standard style.
Would like the ability to select multiple dimensions and change their standard style in the viewport where the text and arrows display on the sheet according to the sizes in that standard style.
3. I am sure this is already known, but adding additional text to dimensions does not always work well. You cannot center the text or right justify the text.  The text overlaps with break in dimensions.
4. Would be nice to have multiline text with dimensions and leaders.  I know that has been said before.
5. Would like to be able to add symbols to text and dimensions like countersink, counterbore, degrees, etc.
6. Would like to see an option for text to blot out the text background. Sometimes you have to trim out a spot in the drawing to place the text.
Sam
Edited by user Thursday, October 29, 2020 7:09:09 PM(UTC)
 | Reason: Not specified
