Hi all, I've been having this issue with via cad 2d/3d, whenever I start the application it seems that the settings I have changed in preferences previously are all reverted to factory. For example I change units from inches to metric in one session, then quit the application and re open it, and all settings would have been reverted to defaults. Right now I am not really sure what else I can do. via cad 12 Win 10
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
Maybe it help when you run the Application as administrator. Punchcad use the config folders in windows: C:\Users\%username%\AppData\Local\Punch!\
This frolder should be protected and if it protected is something wrong with your setup.
Edited by user Saturday, May 23, 2020 1:35:50 PM(UTC)
