They've taken ACIS out of 2D/3D. VC 2D/3D doesn't interop .igs, .stp and .sat anymore, no push/pull, no MTS, no blend or shell, no "advanced surface/solid modelling" - all ACIS.  I started using PunchCAD at its first release, V5, in 2007 because the ACIS routines and interop made it great bang-for-buck and hugely useful as a complement to TurboCAD Pro.  I bought it almost as an impulse buy and because of that, I was completely comfortable about the length of time it took me to learn to use it well (real men don't need instruction, so everything was suck it and see.  Probably a year of dabbling...).  I moved up to SharkFX at V7, because everything I'd done with VC is still usable.  2D/3D V12 is not an upgrade over earlier versions, and it's not a compelling first step in CAD anymore, either.  The 3D printing utilities are useful, but not unique.  If there was a decision between ACIS or D-C constraints, I think they made the wrong choice.  The comparison page says it does Skin, Cover, Net, Extrude, Lathe, Sweep, and .dwg is the only export format remaining that can describe curved surfaces, so are these curved surfaces or meshes in .dwg?
Earlier 2D/3D also do .spl spline/polyline import by coordinate list and curve and surface by law, .dat grid nurbs surface by coordinate.  Are they moved up to Pro only now too?
Edited by user Sunday, June 14, 2020 11:24:52 PM(UTC)
 | Reason: Not specified
