#1 Posted : Thursday, August 13, 2020 7:55:05 AM(UTC)
Was thanked: 110 time(s) in 86 post(s)
Afternoon all.
I have a set of curves which are best fitted from some scanned data. I'm trying to create a revolve using them all. I've attached the file with them in. 6 Sections and a centre line. I've had some absolutely crazy results which clearly aren't right, and others which fail either with a warning of "this feature is not yet implemented" or some other illegal act which I didn't understand
Any help would be great.
Cheers
TCT00108.sfx (24kb) downloaded 10 time(s).
ViaCAD Pro 10, 11 + Power Pack Pro
Shark CAD V12 + Power Pack Pro
Windows 10 Pro- MSI GL72 6QC-32GB RAM
Art Smith
#2 Posted : Thursday, August 13, 2020 12:44:21 PM(UTC)
Art Smith
Was thanked: 26 time(s) in 15 post(s)
UGMENTALCASE-
played with your set of curves for a while and got nowhere. "Skin" would yield a surface for the N curves but would not close the surface gap between the first and last curve...... picking the N curves with a different starting curve yielded slightly different surfaces with the gap in different places..... the shortest curve always induced a twist unless it was at the beginning or end of the sequence of curves submitted to "Skin". best of luck with your challenge
be well
Art
[email protected]
#3 Posted : Thursday, August 13, 2020 1:48:56 PM(UTC)
Hi thanks for giving it a blast for me. I'm the same. I can use more sections, but I'm sure I've done stuff like this before. Just can't figure it!
L. Banasky
#4 Posted : Thursday, August 13, 2020 1:49:44 PM(UTC)
L. Banasky
Was thanked: 88 time(s) in 71 post(s)
Played around with it, probably not what you are looking for.
Just a WAG.
#5 Posted : Thursday, August 13, 2020 2:00:26 PM(UTC)
So what have you done there Larry? I'm actually getting it to work but it will need 4 more section to get the rounded shape better. I'm actually getting different results now I've saved turned off and opened it up again!
L. Banasky
#6 Posted : Thursday, August 13, 2020 4:14:28 PM(UTC)
L. Banasky
I just drew a line to close each objects endpoints, and did a 'REVOLVE' solid, using the
line in the middle.
I almost never work with surfaces, so I really don't know what I'm doing.
#7 Posted : Thursday, August 13, 2020 4:21:33 PM(UTC)
Ah ok got you. Yeah just make them closed profiles. Ok cool cheers :-)
murray
#8 Posted : Monday, August 17, 2020 8:36:55 AM(UTC)
murray
Was thanked: 75 time(s) in 60 post(s)
They can be done as surfaces with Shark's tools, two-point revolved surface worked for me, shift-selecting the profiles, releasing and nominating the axis' end points. Verify count says 6 arcs and 15 lines for the profiles, 21 surfaces are the result. But I passed a cut section through the surfaces afterwards and they're really incoherent, there's not an obvious closed profile for a solid, no evident design intent.
incoherent profiles.PNG (22kb) downloaded 1 time(s).
luk72
#9 Posted : Sunday, January 03, 2021 4:57:59 PM(UTC)
luk72
Was thanked: 12 time(s) in 6 post(s)
Afternoon all.
Cheers
Enjoy!
TCT00108_3_fillettwolines-rad0,2mm.sfx (27kb) downloaded 2 time(s).
TCT00108_4_edit-changeobjecttype-bezier.sfx (29kb) downloaded 1 time(s).
TCT00108_5_jojncurve.sfx (89kb) downloaded 1 time(s).
TCT00108_6_interpolatespline.sfx (91kb) downloaded 1 time(s).
TCT00108_7_guideskinsurface.sfx (132kb) downloaded 2 time(s).
luk72
#10 Posted : Sunday, January 03, 2021 5:00:59 PM(UTC)
luk72
Afternoon all.
Cheers
Result. Enjoy!
luk72 attached the following image(s):
Zrzut ekranu 2021-01-04 001010.jpg (148kb) downloaded 10 time(s).
