#1 Posted : Thursday, March 25, 2021 3:50:27 AM(UTC)
I have a new Error at my Installation. SharkCAD 10 Build 1369 creating only Dimensions in Inch. Every prevs are ignored. This new created Dimensions can not be changed to millimeters, all settings will be ignored. I have no idea how to get back the old Functionality. I hope anyone know a solution for this Problem.
My Windows Version is: 20H2 (Build 19042.867)
Edited by user Thursday, March 25, 2021 4:09:06 AM(UTC)  | Reason: Not specified
magicart
#2 Posted : Friday, March 26, 2021 4:04:06 AM(UTC)
magicart
Poland
Hello MPSchmied,
I also use Shark Pro v10 build 1369 and don't have such problem at all. Maybe reinstall shark again or make sure you have unit "mm" (or "follow prefs" in dimension window) when You have nothing selected.
Magicart
#3 Posted : Friday, March 26, 2021 6:55:32 AM(UTC)
Originally Posted by: magicart Go to Quoted Post
Hello MPSchmied,
Magicart
My Prefs was in mm, you see it in the screenshot and this error-Dimensions are resistent against changing the Prefs and the Error was also my Installation of the german Version Build 1341. But i found now a Solution for the Problem: Change the Settings for new Dimensions also when you have already the right settings for new dimensions, and create some new dimensions and change the settings later back to the right settings. This changing will remove the error.
Edited by user Friday, March 26, 2021 6:57:20 AM(UTC)  | Reason: Not specified
GARLIC on 3/26/2021(UTC), magicart on 3/29/2021(UTC)
