Hi Perry,
I am on Win 11 P.C.,I don't know too much about the Mac system.
I know they update the Operating System often, and it causes
problems with ViaCad and Shark.
Was your Ver.12 .dxf on the same Operating System as your Ver. 14 .dxf?
If you can post both files, a Mac user can verify and help.
I use Mach3 and SheetCAM on the plasma cutter, and Mach4 and SheetCAM
on the CNC mill.
.STL files on the 3D printer.
I noticed a small line on the upper left corner of your drawing.
This would cause the plasma cutter and the mill to also go to this point
on my machines.
The software will remove duplicate lines, but the short line is not a
duplicate line, and the machine will want to cut it.
The short video shows how simple it is to export a good .dxf, only takes
seconds, especially if the holes are put in with the Hole Command.
https://www.dropbox.com/...su9qo4f8gy22378&dl=0Edited by user Wednesday, March 27, 2024 11:35:57 AM(UTC)
| Reason: Added Link
(18kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
