Originally Posted by: jol ![Go to Quoted Post Go to Quoted Post](/Themes/punchcad2/icon_latest_reply.gif)
Personally, I avoid M2S whenever possible because I hate it
So do I, but I definitely need it...I fully support
Jol's 12 points and I can add many more :
13 - correct bug of "squeezing solid" when zooming in a rendered view
14 - have a real inspector function regrouping all text and font parameters (like other softs).
15 - Same thing for dimension parameters.
16 - Same thing for Hatches.
17 - Make area selection work (as it was on Vellum 2.7) for hatching.
18 - Let lines be lines, and arcs be arcs, not just dumb splines.
19 - have a really functioning regen toggle (manual/auto), globally (not view by view).
20 - Solve the detail views bugs when regen.
21 - Hatch not working in detail views (recognized as lines).
22 - have line weights and style saved correctly with the file (when I open on different computers, it changes)
I stop here. When those will be corrected, I will add a few more...
Advise to the new comers :
until Tim solves the issues, always "print as pdf" every drawing when it's finished, because if you want to open the file next month or next year, it may be totally messed-up with text, dimensions and lines displayed differently, or even missing completely. Most of my old files are like that...
Another advise : if your work is complex, don't do MTS on your reference 3D work file. Make a copy before...
