                I haven't been able to find anything regarding this - I must have missed it somewhere:
                Nick recently told me that if you select all entities, then by using the trim tool, you can just knock selected ones out as you wish (a la Solidworks!)
                Thanks ttrw!
                You might like to try this work-around.
                Originally Posted by: dexter  Thanks ttrw!
FYI: In Rhino, trimming multiple lines is done by using the selection window to 'hit' the bits you wish to remove..similar to how the select tool works thats what we need??
HTH
                Checkout the avi in my post...trimming like this is a breeze & a 'must have' for VC:p
                Yes, that would be a very nice option for the tool - dragging a box right-to-left or vice versa would change what is deleted on the side of the selected trim line...
                Originally Posted by: Alan Bransom  You might like to try this work-around.
Thanks, Alan!
That works great, but still requires a lot of clicks.
Thanks for pointing this out Alan.....this would be an acceptable way and quick if VC  allowed window section when it asks "Select curve to trim to selected curves" then it wouldn't be such a long winded workaround, to me anyway. - Tim ??
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
