Neil Hayes
#1 Posted : Sunday, June 03, 2007 10:03:33 AM(UTC)
Neil Hayes
Hello,
I create a lot of 2D profiles for my archvis work and I wondered if its possible to define the number of interpolations on a per curve basis within ViaCAD? e.g. I could set 10 points for a specific cubic bezier curve etc.
Furthermore, could I also do this for circle segments etc.? For example, say I have an elliptical segment that I wish to convert to a polyline is it possible to alter the number of points that are used to approximate that curve? ... I assume if this works I could export as DXF and maintain that number of points.
thanks,
-neil
#2 Posted : Sunday, June 03, 2007 2:05:52 PM(UTC)
Was thanked: 244 time(s) in 211 post(s)
>>I wondered if its possible to define the number of interpolations on a per >>curve basis within ViaCAD? e.g. I could set 10 points for a specific cubic >>bezier curve etc.
The display lists point positions are calcuated on a chordal deviation. When you convert a spline to a polyline, it is using the display list.
We do have a create points along curve tool that might work for you.(Located in the Point tool palette).
Vice President Software Development
