#1 Posted : Sunday, September 4, 2011 8:18:43 AM(UTC)
Was thanked: 171 time(s) in 103 post(s)
On attached file :
Bug #1 : the number of element in layer is wrong. 9 in inspector & 13 in layer. The red grouped profile counts as 5 elements (4 conics + 1 group). It should be just 1.
Bug #2 : stitch the surfaces destroys the red group. Transformed to 4 original conic elements.
Bug #3 : get back to the grouped red profile, rebuild the surfaces (cover + guide cover with green arcs). stitch by selecting all. The red group just disappear. It get stitched with the surfaces...
I could replicate that many times.
Bug cover.sfx (17kb) downloaded 5 time(s).
Capture d™©cran 2011-09-04 15.49.45.jpg (34kb) downloaded 0 time(s).
#2 Posted : Tuesday, September 6, 2011 12:05:56 PM(UTC)
>>Bug #2 : stitch the surfaces destroys the red group. Transformed to 4 >>original conic elements.
Fixed in 990. When you select an item to stitch, it will turn it off what you selected after a successful stitch. I now check that it is a valid item to stitch.
(I suspect you selected the group with four conics to stitch into a solid along with the surfaces.)
#3 Posted : Tuesday, September 6, 2011 12:33:02 PM(UTC)
> layer. The red grouped profile counts as 5 elements (4 conics + 1 group). It > should be just 1.
Fixed in 990. Objects within a group no longer count as an item in the layer manager, follows counting logic in Inspector.
