joev
#1 Posted : Monday, April 9, 2007 11:31:06 AM(UTC)
joev
Is there a way to have a starting profile and an ending profile for a sweep? The two profiles would be different sizes of the same profile.
And is it my imagination -- but didn't the Skin Solid tool have an option to use a guide in the previous build of Concepts 3D? I'm using b660.
I just checked the previous build (658) and it did have that option.
Todd Quinlan
#2 Posted : Monday, April 23, 2007 8:09:24 AM(UTC)
Todd Quinlan
To do the two Profile sweep you want to use the Skin solid tool. This will give you the option to do a straight sweep. In CU you also have the option of doing a Guided sweep.
It is not your imagination, the guided sweep in C3D is no longer avalalible in Build 660
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
