Can't re-authorize Concepts3D (#711)
                I'm having to authorize concepts3d again due to hardware changes, yet again ;)
                I think there is a limited number of installs, but Tim can add additional installs to your license if needed. Same thing happened to me.
                Well, i changed the video card, sound card and a new HDD, fresh OS install, now i'm stuck.
                If you're using SP4 then it's probably because new authorisation site hasn't had existing client codes migrated to it.  In the UK we've just been adding on a case by case basis until migration complete.
                Ahh its not SP4, maybe i'll try reverse logic then ;)
                Reuben
If you have downloaded C3D SP4, then it will bring you over to the new registration URL.
If you are registering an older version, you will need to register manually using the new link below.
http://register.punchsoftware.com/registration.cfm Your node id is displayed when you launch the program in the registration dialog box.
                Hi Tim,
                I got this when trying to register my current version-
                >>We were unable to locate an available registration
If you are registering a pre SP4 product, then you must register it using the link below.
http://register.punchsoftware.com/registration.cfm     Tim Olson
                >>but i had heard there was some problems with it, have they been fixed yet
                I've got 2 serious bugs in SP4 that making using it a pain - documented
                Still can't register, i downloaded SP4 build 667 from a link on this forum, this or SP3 won't register, email sent to punch support....
                I got sorted out today, needed a new registration key, thanks :)
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
