New user here, just picked up VC two days ago. I am looking to it as an addition to Modo and have been testing going from VC to Modo using DXF. Sadly, many complex objects simply don't export, at all. I get truncated or empty DXF files, and the export dialog seems to close without completing the progress bars.
Simple objects work fine, cubes, spheres, etc. But trying to export the bundled engine model from the "rendering the drawing" tutorial creates a seemingly incomplete 12kb file. I say incomplete because importing into Modo creates a properly named layer, but shows no geometry.
Trying to export the attached test file, which I turned into a mesh object in the hopes that it would be a workaround, also does not work. It instead generates a 0KB file.
I'm running Leopard, wondering if it could have anything to do with it since I can't seem to find any other DXF complaints on the forums?
I use the R12 format to make sure it's a faceted mesh, and I tried playing with the units as well as converting to a mesh before exporting.
export_test.vc3.zip
(955kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
