terry bean
#1 Posted : Tuesday, March 11, 2014 9:17:38 AM(UTC)
terry bean
Is there a problem with the angular dimension tool when working with solids?
I can get vertical and horizontal dimensions OK but when working with the angular dimension, it doesn't recognize any of the lines.
I'm making a simple mailbox post with a angled brace between the horizontal and vertical boards. I'm using my calculator to figure out the cut angle on my saw. I shouldn't have to do that
It would be great to use the angular dimension tool with solids without the need to draw two lines on the solid to create the angle with the angle tool. This is the only method I know of.
I have ViaCAD Pro v8
Would appreciate anyone's advice
Terry
