Shark supports HDRI rendering which significantly improves the lighting of photo rendered images. The Render Library has a tab called "HDR Backgrounds" that displays drag and drop HDRI's into your drawing.
The HDRI files are located in the PhotoRender : Hdri folder which is located in the application folder. These files have a .hdr extension.
Tip:
You can add more HDR files to the Render library interface by copying the files into the above folder. You will need to relaunch the app.
In builds 1113 and later, you can add .exr files to this folder.
For more information on exr, visit
www.openexr.com .
