Suggestions
Shark CAD can't remember the Print Setup
Thanks: 269 times Was thanked: 131 time(s) in 101 post(s)
When restarting the program the print setup will be resetted to the standard printer, this is on my main system the pdf creator. A good was will be, Shark CAD save the print setup to the file and not to the main setup. Otherwise i can change the standard-printer in windows, but most time i print with the PDF Creator and under Windows is the changing of standard printer a little bit annoying.
Edited by user Sunday, July 2, 2017 2:28:17 AM(UTC)
Suggestions
