Jalaluddin
#1 Posted : Friday, October 20, 2017 10:03:22 PM(UTC)
Jalaluddin
I have labelled vertices and edges of a triakis truncated tetrahedron, but there is a lot of visual clutter as the labels are not hidden.
Is there a way to make them hide?
Otherwise hiding text is on my wish list for SharkCAD PRO 10.
Thanks in advance.
Jalaluddin
Edited by user Friday, October 20, 2017 10:05:30 PM(UTC)  | Reason: Not specified
triakis_tt.sfx (246kb) downloaded 6 time(s).
L. Banasky
#2 Posted : Saturday, October 21, 2017 6:02:35 AM(UTC)
L. Banasky
Hi Jalaluddin,
Right Click, Hide All-Text + Dimensions.
Hide All -Text + Dimensions.jpg (78kb) downloaded 3 time(s).
#3 Posted : Monday, October 23, 2017 3:27:03 AM(UTC)
If you want that your numbers are hidden by your object and only the numbers in foreground visible you cant use the Option "Screen Horiz". For this you have to create a new Working Plane for every Number for text in 3D Space. That the Screen Horiz. Text should be hidden by the Solid is maybe a good idea and is now also in my wishlist.
