Andrew Gray
#1 Posted : Saturday, July 14, 2018 5:59:33 AM(UTC)
Andrew Gray
Hi All
Just want to check if this is right
if I place a block primitive (or any other type) and set the sizes, I can move the block and still control the parameters but if I copy the block then I cant change the block parameters
assy.vc3 (22kb) downloaded 2 time(s).
#2 Posted : Saturday, July 14, 2018 6:33:36 AM(UTC)
Have you tried the copy with history? Right click the block somewhere in that list is duplicate with history, does this work for you?
Cheers
Andrew Gray
#3 Posted : Saturday, July 14, 2018 4:20:35 PM(UTC)
Andrew Gray
thanks all good
Andrew
