jcrous
#1 Posted : Thursday, April 11, 2019 1:11:51 PM(UTC)
jcrous
South Africa
I want to draw two plough shares, a side plough and a digger.
I want to draw the shape of the plough blades in 2D to scale and then extrude to thickness.
I am not sure how to do a soft bend, with a big radius. Both blades will require two bends at least.
Edited by user Thursday, April 11, 2019 1:14:55 PM(UTC)  | Reason: Not specified
Johan Crous
L. Banasky
#2 Posted : Thursday, April 11, 2019 5:23:42 PM(UTC)
L. Banasky
Was thanked: 163 time(s) in 112 post(s)
You can draw the 2d shape, extrude, and use the Curve Bend tool,
if this is what you are looking for.
Upload a sketch for ideas, and what version you are using.
Edited by user Thursday, April 11, 2019 5:25:33 PM(UTC)  | Reason: Not specified
Curve Bend.jpg (104kb) downloaded 6 time(s).
jcrous
#3 Posted : Friday, April 12, 2019 11:53:07 PM(UTC)
jcrous
South Africa
Thank, I will try.
I am using Viacad Pro 11.
Just upgraded from 9.
Johan Crous
