flatpack
#1 Posted : Saturday, August 17, 2019 6:03:27 PM(UTC)
flatpack
Was thanked: 11 time(s) in 9 post(s)
Anyone have any experience with modeling a tufted look?
I'm trying to figure out a rapid way to model tufting on sofas or chairs.
Would be just for rendering purposes, but a texture of tufting isn't going to cut it..
I attached this diamond pattern here just as an example..
Thanks in advance.
Tufted sofa.png (189kb) downloaded 3 time(s).
digitalphaser
#2 Posted : Sunday, August 18, 2019 4:22:43 AM(UTC)
digitalphaser
Was thanked: 43 time(s) in 35 post(s)
Once I modeled a chair with such a tufted back. I modeled a chair with Shark and quilted upholstery with mesh modeler(in my case Silo 3D).
If you do it for visualization(renderin), then zBrush+MeshEditor combination is ideal for such tasks.
The VC/Shark does not have suitable tools for this. Shark's Mesh Tool is too poor. With Net Surface is probably possible. But I don’t think it will be easy. In addition, this is diamond-shaped pattern.... :( Difficult!
The most likely option is a normal surface modeling. But it will be long and difficult too.
thanks 1 user thanked digitalphaser for this useful post.
flatpack on 8/18/2019(UTC)
GARLIC
#3 Posted : Sunday, August 18, 2019 4:45:31 AM(UTC)
GARLIC
Was thanked: 16 time(s) in 14 post(s)
What about the "Pressure Deform" function ? by creating a surface to a defined boundary and apply
a pressure, one has to try different "gain" values to obtain the desired shapes.... just my 2 cts
-regards-
G.
thanks 1 user thanked GARLIC for this useful post.
flatpack
#4 Posted : Sunday, August 18, 2019 9:27:47 AM(UTC)
flatpack
Thanks! I only need it for rendering/visualization. I thought about using surfaces but it seems really complex as you've pointed out. I wish the mesh tools were a bit easier. They do have so much potential considering theyre conveniently built right into the program.
flatpack
#5 Posted : Sunday, August 18, 2019 9:31:21 AM(UTC)
flatpack
-regards-
G.
Awesome suggestion – thanks Garlic! I also thought about "Insert Knots" to the surfaces to push/pull various areas in and out.
thanks 1 user thanked flatpack for this useful post.
GARLIC on 8/18/2019(UTC)
flatpack
#6 Posted : Sunday, August 18, 2019 9:35:06 AM(UTC)
flatpack
Could you please explain how to get started with this method? Or if you could point me to an existing tutorial? I am not certain how to get those circles to connect to the Net lines. Thank you!
#7 Posted : Sunday, August 18, 2019 10:53:13 AM(UTC)
Was thanked: 64 time(s) in 54 post(s)
If you are using V10 do you still have the deform face tool? Would that work?
Shark CAD + Power Pack Pro
flatpack
#8 Posted : Sunday, August 18, 2019 2:14:48 PM(UTC)
flatpack
Yeah I'm using SharkCAD v10. It has Pressure Deform, Curve Deform, Point Deform. I don't see a Face Deform... maybe Pressure is it?
THanks!
digitalphaser
#9 Posted : Sunday, August 18, 2019 3:22:43 PM(UTC)
digitalphaser
Here's a short video with a basic diamond mesh. For a better result, you will certainly need more splines.
https://youtu.be/JKqMsBV15Ok
flatpack on 8/19/2019(UTC)
murray
#10 Posted : Sunday, August 18, 2019 7:41:33 PM(UTC)
murray
Was thanked: 39 time(s) in 34 post(s)
Quilting like this is an array of a thing called a Gregory surface, this one's done in Marcus Bole's PolyCAD program, very similar to pressure load, although the curved edges between the tufts are trimmed in from the edges of a Gregory, which are flat. Pressure load is Deform Face in SCP V10. Skin surface or solid with a symmetrical curve between two lines looks the same, too. Overlap the array, there's no need to try to meet edge to edge.
Edited by user Sunday, August 18, 2019 8:40:08 PM(UTC)  | Reason: Not specified
Gregory surface.PNG (22kb) downloaded 1 time(s).
pressure load array.PNG (101kb) downloaded 4 time(s).
skin solid Gregory.PNG (33kb) downloaded 4 time(s).
thanks 2 users thanked murray for this useful post.
GARLIC on 8/19/2019(UTC), flatpack on 8/19/2019(UTC)
flatpack
#11 Posted : Monday, August 19, 2019 5:46:39 AM(UTC)
flatpack
Thank you! This is extremely helpful.
digitalphaser
#12 Posted : Monday, August 19, 2019 8:37:27 AM(UTC)
digitalphaser
You welcome! :)
digitalphaser
#13 Posted : Saturday, August 31, 2019 12:21:49 PM(UTC)
digitalphaser
I often watch Arrimus 3D tutorial channel. There is one interesting tutorial: "Tiling Sofa Geometry" - https://youtu.be/fFSVUbHuHB8
This is of course another software. But the principle can be used easily in any other software.
thanks 2 users thanked digitalphaser for this useful post.
flatpack on 9/1/2019(UTC), jlm on 9/2/2019(UTC)
