I just upgraded ViaCad 2D3D from version 8 to version 11 and when I open version 11 it won't let me select any of the options in the menu. While I can use the default dynamic pan, I can see but not select either of the other two options. The same goes for all of the other tools in the menu. I am on a 2019 iMac with Mojave. Please help! Thanks, Mike
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
dynamic pan you get when you press the space button while using any other tool. Dynamic rotate with the middle mouse button. But you have a mac and maybe no middle mouse. And no idea where the alt button on mac.
If you cant select the other tools you should maybe upgrading your installation to Build 1441. If you not have Build 1441 i can send you a download link via PN.
Edited by user Thursday, August 29, 2019 10:22:16 AM(UTC)
I sent you the Link for downloading via PN ViaCAD2D3D11_1441_WIP.dmg
