jb2953
#1 Posted : Tuesday, January 10, 2012 8:19:19 PM(UTC)
jb2953
When i select a paper size in model to sheet and dimension my drawing is it possible to change that drawing to a different size paper.
#2 Posted : Wednesday, January 11, 2012 1:36:55 AM(UTC)
Was thanked: 180 time(s) in 108 post(s)
Yes it is possible.
There are a few points to be improved in the "page layout" dialog :
- "single page" often leads to... several pages. To get ONE page select 1 raw and 1 column.
-"Engineering" always pop up as a default, though I always use metric.
- The position of the page frame change when I reopen the same file on another computer.
I'm sure Tim will finally improve these points :rolleyes:
JL
#3 Posted : Monday, April 2, 2012 4:16:51 PM(UTC)
After 3+ years of using VC/VCP/ and now Shark, I decided to try Model to Sheet. It was confusing at first. For the most part I'm okay with it.
But, since my model is a 177m ship and has thousands of entities, it sometimes bogs to a crawl of minutes of no response if I check/turn on the setting to preview the model.
I have had to task-kill VCP/Shark several times when I no longer wanted to wait.
Overall, though, I think I like it enough to make regular use of it, but it would be nice if the viewports/overall user experience were more manageable/neater..
