Need to grow a block, keep what is drawn already in the same place (#4431)
I use Viacad pro, version 7. I drew an aluminum manifold, which is basically a block with a punch of fancy holes. Customer wants bigger mounting holes so the block will grow from 4.5" x 4.5" x 6.75", to 4.5" x 4.5" x 7". When I select the block and change the length dimension, it adds the 1/4" to the one end, instead of what I want to do, which is add an 1/8 on one side, and an 1/8 on the other. What is the easiest way to do what I'm trying to do, or do I need to just add the 1/4 then move every detail?
"Offset face" tool, move the end faces 1/8" each is probably the short'n'sweetest.
Originally Posted by: zumer "Offset face" tool, move the end faces 1/8" each is probably the short'n'sweetest.
Thanks!
Sorry for the newbie question, but where on the pallet do I find it?
Local face operations flyout.
(30kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
