Originally Posted by: Gary In the draw view properties dialog of each draw view there is an option to "regen manually". select this for each view. When you are ready to regen, select the regen view tool (last tool in tool bar where model to sheet tool is).
Gary
I couldn't find the draw view properties dialog for each view?
Using your answer, I searched support looking for where the view properties dialog might be, and stumbled upon that I could turn off "Enable Auto Resolve", which seems to have done what I wanted.
However, one of the changes I made to the model was to import another part and add to my model. I'm not sure why, but the new imported part came in on a separate layer, and did not show up in the sheet. I guessed, maybe incorrectly, that to get it to show up in sheet view, I should move it to the same layer with all the other parts that are currently shown in sheet view. I *think* I figured out how to do that, but it still will not show up in the sheet view. When I select the regen view tool, I get a message that all views are up to date?
I also tried to resolve links under the edit menu, but that option is "greyed out"?
BTW, I am using ViaCad 3d version 6 on a Mac, if that matters to your answer.
And thank you for your initial response, and any further insight you may be able to impart.
