I tried doing some searches and found some related threads, but none that applied directly to what I want to do.
I want to design hydraulic valve manifolds. For those not familiar, they basically are a rectangular block of aluminum or steel with special "cavities" drilled into them that accept cartridge valves.
The cavities are like counterbored holes with several different diameters and radiuses (radii?).
I have found the profile of the cavities as .dxfs online. They can be imported and lathed around their center axis to make a "positive" of the cavity. Then I can move them to the block, do a subtract object, and I have my cavity in the block.
The problem is, once this fancy hole is in the block, I can't seem to do anything with it? I can't select it, as I end up just selecting the block that contains the hole, I can dimension it, as it is just a void with no center.
I tried just leaving them as a bunch of solids so I could move them around, but it didn't take to long until selecting one "positive" of a given cavity at a time became a problem, as I'd end up selecting parts of other cavities or ports.
I attached a sample of a "lathed" cavity profile so you can get an idea of what a typical cavity looks like.
Any thoughts?
![](/Themes/punchcad2/icon_file.gif)
VC16-6.vcp
(215kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
