klais
#1 Posted : Friday, August 20, 2010 4:07:22 PM(UTC)
klais
I can't seem to get the line pattern set to "CUTTING" when generating a section view. Selecting the cutting plane line and changing the pattern in the inspector seems to have no affect on the display of the cutting plane line. Is there another step I am missing?
Regards,
Kevin
klais attached the following image(s):
Screen shot 2010-08-20 at 2.55.37 PM.jpg (31kb) downloaded 5 time(s).
#2 Posted : Wednesday, August 25, 2010 4:31:29 AM(UTC)
Regards,
Kevin
Hi Kevin
Until this gets updated, you can always draw a small line change it to whatever color line type/patten thickness you want then use the eyedropper tool to copy and paste to your section lines.
klais
#3 Posted : Wednesday, August 25, 2010 9:24:58 PM(UTC)
klais
This works great. Thanks for your advice Jason.
Regards,
Kevin
Guest (5)
