#1 Posted : Saturday, June 25, 2011 4:58:47 PM(UTC)
hello, something it is going wrong with referenced geometry on grouped objects, i been experiencing this on build fx 967-mac, normally this happen when a grouped object is moved whit the gripper handles an the undo command after that, please see the picture attached,
I tried to upload a video and i could't, so please check it a this link for it: http://www.miditec.com.mx/sharkvids/badgeoreference.mov
anyone else has experienced the same?
Luis G.
MacOSX Sonoma 14.7.1
#2 Posted : Saturday, June 25, 2011 8:13:19 PM(UTC)
I can't seem to get the link to the movie to work.
billbedford
#3 Posted : Sunday, June 26, 2011 2:08:08 AM(UTC)
billbedford
These is certainly a problem with the gripper when used to make a copy. In 936 if you copy using the gripper and enter a distance in the box the copy disappears [ATTACH]3914[/ATTACH]
In 969 the effect is weirder...
[ATTACH]3915[/ATTACH]
Gripper copy problem.mov (1,735kb) downloaded 0 time(s).
Gripper copy problem-2.mov (369kb) downloaded 0 time(s).
Ryan Anderson
#4 Posted : Sunday, June 26, 2011 8:38:44 AM(UTC)
Ryan Anderson
This is also a problem in Viacad 2d/3d V8 beta.
#5 Posted : Sunday, June 26, 2011 11:37:01 AM(UTC)
Link is working fine for me, anyone else can't see the video?
#6 Posted : Sunday, June 26, 2011 1:55:21 PM(UTC)
Gripper copy bug fixed in next upload.
#7 Posted : Monday, June 27, 2011 1:40:52 PM(UTC)
Probably this is unrelated, but in VCP 7, when I import some geometry, it just vanishes. It is restored and persists (behaves correctly) if I turn off then back on that respective geometry's layer. I am not sure if the code is related, and I am not sure if it is related to using FreeShip 3.22/3.23+.
