Why undo command regen sheet views? (#4304)
Thanks: 18 times Was thanked: 21 time(s) in 18 post(s)
so, this is the question: Why undo command regen sheet views? Is there anyway to avoid this? is quite annoying and time waste every time that i did a minor change, if i want step back, i have to wait several minutes for views regeneration or links resolve. I have the "enable auto resolve" option unchecked on preferences. So, any solution? Luis G.
Hi Luis
Did you try checking the regen manually box in the draw view properties?
(14kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 231 times Was thanked: 183 time(s) in 110 post(s)
Originally Posted by: lgrijalva Why undo command regen sheet views?
Thanks Luis, to ask the question.
I always wondered why...
Originally Posted by: jdi000 Did you try checking the regen manually box in the draw view properties?
Hi Jason,
I often do that, but it has to be done for every individual view.
I'm dreaming of a global preference "regen all views manually".
