NorthridgeFab
#1 Posted : Wednesday, January 8, 2014 10:15:28 AM(UTC)
NorthridgeFab
I have a macbook with a external monitor. Anyone know how to move the menu bar and the bar right below the menu bar to the external monitor? I can drag the tools and drawing.
NicoCho
#2 Posted : Thursday, January 9, 2014 1:44:58 PM(UTC)
NicoCho
open System Preferences and select Displays. You should see your 2 displays in the Display tab. If not, make sure the mirror option is unchecked. Drag the menu bar from the built-in display to the external one. That should be it. You can also adjust the relative position of the two displays.
Regards,
Nicolas
