Suggestions
CutOut Solid tool for splitting (#1919)
Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Tim, Can we have an option in "CutOut Solid" tool to keep parts being cutout/removed? Lets say, holding "Option" key would let to keep parts of solid, which are normally removed during cutout. This way we would perform splitting only action.
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
Have you tried Subtract Solid using the button you speak of retains the part you need? HTH
Originally Posted by: unique Have you tried Subtract Solid using the button you speak of retains the part you need? HTH
Holding option key in "Subtract Solid" tool, retains part used to subtract but still removes intersecting part of solid to subtract from.
Try to split attached "Solid slab" into individual parts.
Can anyone offer an effective method of doing it with any tool available in Shark?
Ability to cut/split solids with closed curves or polygons would make problems like this trivial.
Solid slab.sfx
(190kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Hi Mark,
Yep, Boolean Split is what you are requesting (See the icon picture)
Excellent suggestion & addition this would be to VC !!
unique attached the following image(s):
(99kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: unique Hi Mark, Yep, Boolean Split is what you are requesting (See the icon picture) Excellent suggestion & addition this would be to VC !!
You are wright. Boolean Split would be perfect addition.
What is the software shown on your screenshots?
A boolean would be logical as well - hope Tim & co are taking notes
Originally Posted by: Mark You are wright. Boolean Split would be perfect addition. What is the software shown on your screenshots?
That would be from Rhino.
Suggestions
