Mark
#1 Posted : Wednesday, December 24, 2008 11:44:51 AM(UTC)
Mark
Here is an example problem I am trying to solve:
1. Created attached "Solid slab" model with series of angled surfaces.
2. Changed object type to "Surfaces"
Now I am trying to place all resulted surfaces horizontally in XY plane, so I can later generate CNC Machine Code for cutting them in laminate sheet.
I can't find the way to do it in Shark?
Any suggestions are highly appreciated.
Solid slab.sfx (190kb) downloaded 4 time(s).
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
L. Banasky
#2 Posted : Thursday, December 25, 2008 5:04:12 AM(UTC)
L. Banasky
Mark,
First of all thats a big sheet 60" X 72". I selected all, Model-to-Sheet, delete unwanted views, delete border and title block. Flatten the view and change the lineweight, using obj. pen, I used .002". Export as .dxf.
I use Sheet-Cam and usually cut individual pieces, which creates the problem of having to draw and mark your pieces one-by-one. I opened your drawing in Sheet-Cam, just to see if this is what you're looking for. I might be way off base on what you want to do. The screen shot is from Sheet-Cam.
unique
#3 Posted : Thursday, December 25, 2008 7:55:55 AM(UTC)
unique
Hi Mark,
I currently use VC and there is not facility in there....same with Shark from what you say.
In Rhino I can "unroll" (flatten) surfaces, I believe this would work on your part but I cannot open it to try it;). Checkout attached file by importing the Rhino file into Shark (check the heal auto heal solids box), Then select all items and change display to U&V=1
I would be happy to try your file if you save out as VC or ACIS - Happy Xmas!
example.zip (29kb) downloaded 4 time(s).
Mark
#4 Posted : Friday, December 26, 2008 6:50:38 PM(UTC)
Mark
Originally Posted by: unique Go to Quoted Post
Hi Mark,
Thanks to all for advice. It looks like Rhino can solve a lot of my problems.
unique,
Attached is ACIS 6.0 version of the model to try in Rhino.
Thank you.
Surfaces.sat.zip (101kb) downloaded 4 time(s).
unique
#5 Posted : Tuesday, February 10, 2009 6:18:09 PM(UTC)
unique
Hi Mark,
Sorry mate..totally missed your post!!:o:o
Checkout the file attached it has 159 facets:eek:
facets.sat.zip (137kb) downloaded 4 time(s).
