Draw a polyline parallel to a polyline (#4477)
Thanks: 3 times Was thanked: 4 time(s) in 3 post(s)
Hello I have a question concerning polylines, How can i draw a polyline parallel to an existing one? regards Martin
Martin Krueger ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D _myMill self made CNC milling-machine
Your best approach is to drag copy along any axis or use linear array.
Thanks. It was a bit tricky to group the polyline, but it dit work.
Or... You could use the Parallel Line tool in the Line pallet, or even the Offset Curve tool in the Trim pallet :) V8 also has a parallel line drawing feature, so there are plenty of options to choose from. Martin.
