Extrude Solid Problem (#4475)
Thanks: 3 times Was thanked: 4 time(s) in 3 post(s)
Hello
I have a problem with extrution. Can someone please tell me why this file does not extrude correctly. Thanks
kind regards
Martin
ViaCAD v8.0.0 Build(1007)
yw-front.vc3
(199kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Martin Krueger ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D _myMill self made CNC milling-machine
What do you mean by extrude correctly?
Is this what you were looking for?
billbedford attached the following image(s):
(18kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Yes. But this is how it looks if i do it. What have i done wrong?
martinwh99 attached the following image(s):
(8kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
I get a different result. Only the outer perimeter got extruded. So I projected everything on the plane using the project to plane command and that worked for me. I didn't project the small square with its holes only the perimeter and the 5 holes.
Originally Posted by: martinwh99 Yes. But this is how it looks if i do it. What have i done wrong?
It looks as if you have not selected all the line segments. Try selecting one line in the outline and then 'Chain Select' from either the Edit Menu or the Context Menu.
Thanks allot that was the solution. Now everything works fine. Martin
