martinwh99
#1 Posted : Tuesday, January 14, 2014 8:15:32 AM(UTC)
martinwh99
Switzerland
Hello
In my drawing i have skin surfaces and now i'm cutting out 'parts' with infint plane and cut section. I do this in an separate layer select all objects in that layer, group it and move it (change selected object to 'layername') to an an other layer and this all works fine. I store my drawing close it and open it again and it does not show me all Objects of the layer. Also regarding the layer object count they are there. I'm getting mad. Because this is a tricky work and it takes time. I've done it now for the third time always with the same result. can someone please help.
I'm using ViaCAD Pro V8.0.3 Build(1016) on win 8.1 and Win 7 both 64Bit's and both the same result.
Unfortunately due to a security problem i was not able to send the file with this post.
regards
Martin
Martin Krueger
ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D
martinwh99
#2 Posted : Tuesday, January 14, 2014 3:45:59 PM(UTC)
martinwh99
Switzerland
Hello
I think i found the problem. I have all my drawings in the Cloud and i've been working directly with these files. Now I copied the file locally and it seems to work.
Martin
Martin Krueger
Tem
#3 Posted : Thursday, January 16, 2014 12:02:52 PM(UTC)
Tem
Yes, working on local files and saving locally works. Backing up to the cloud is good, but relying on it as you would a local working storage medium is probably not reliable.
