martinwh99
#1 Posted : Friday, February 14, 2014 5:18:56 AM(UTC)
martinwh99
Switzerland
I do have a problem with skin surface depending where i start i get a different skin see pics. Pic 1 i started from the smaller object to the bigger and the skin did not take all (both lines are grouped). Pic2 i did start from the longer object to the smaller. Now on the other side skin is missing. I did redraw the whole drawing now the third time :mad::mad: getting always the same problem. Can someone please help. thanks
regards
Martin
test.vcp (180kb) downloaded 0 time(s).
martinwh99 attached the following image(s):
Martin Krueger
ViaCAD ProV9, Cut2D, Cut3D
Tem
#2 Posted : Tuesday, February 18, 2014 10:35:55 PM(UTC)
Tem
It appears that you need to join the curves that are adjacent to each other, not grouping them.
