Art
#1 Posted : Sunday, September 2, 2007 12:51:39 PM(UTC)
Art
If I am using the "split solid with surface" tool and I select a solid by mistake I simply get the dreaded "spinning wheel" Should not this tool only allow a surface to be selected instead?
Is this a bug or a feature?
Art
MacIntell 4 gig ram
nabed
#2 Posted : Tuesday, September 4, 2007 4:31:45 AM(UTC)
nabed
I think it is a feature, because it actually works with solids.
(solids can be seen as a bunch of joined surfaces that form a closed entity)
Probably the solid you used for splitting was fairly complex, hence the spinning wheel. With a little patience it should work though...
And I agree that the prompt "select surface for splitting solid" is not totally consistent to how the tool actually works.
Ciao, Norbert
Art
#3 Posted : Tuesday, September 4, 2007 8:14:06 AM(UTC)
Art
Norbert,
Thanks, you are exactly right.
Art
