misterrogers
#1 Posted : Sunday, August 19, 2012 8:36:37 PM(UTC)
misterrogers
Can I constrain movement of a part?
e.g. Drawers only able to move in one axis?
Thank you.
rockyroad_us
#2 Posted : Monday, August 20, 2012 8:11:49 AM(UTC)
rockyroad_us
You can lock a part from being touched so no movement at all.
Your goal to restrain only to one axis I don't think is doable. Just use the gripper to restrain to any axis.
misterrogers
#3 Posted : Tuesday, August 21, 2012 9:40:47 AM(UTC)
misterrogers
Thanks, but does that mean I cannot create an assembly where a part is constrained to not pivot more than a certain degree?
rockyroad_us
#4 Posted : Tuesday, August 21, 2012 9:48:55 AM(UTC)
rockyroad_us
If you are talking about animation, you can constraint motion in any linear axis or any rotational axis. Even in rotational degrees.
For the sake of moving a part out of the way, you can use the gripper or the move command while in any plane view.
misterrogers
#5 Posted : Wednesday, August 22, 2012 3:25:17 PM(UTC)
misterrogers
rockyroad that is exactly what I meant - animating while constraining the motion. I should have said animation - thanks!
