misterrogers
#1 Posted : Tuesday, February 28, 2012 9:46:32 AM(UTC)
misterrogers
I get this error message when trying to round the edge by 1mm (its a 15 mm panel). Not complex geometry at all merely a simple extruded profile.
Any ideas what I can do to resolve this? Thanks.
misterrogers attached the following image(s):
Screen shot 2012-02-28 at 9.41.08 AM.jpg (47kb) downloaded 6 time(s).
rockyroad_us
#2 Posted : Tuesday, February 28, 2012 10:07:14 AM(UTC)
rockyroad_us
I think you need to select the edges individually around the perimeter. Not sure what is causing this.
misterrogers
#3 Posted : Tuesday, February 28, 2012 10:19:59 AM(UTC)
misterrogers
Thanks but I just tried that and here's a new message I got. No idea what this means..
Screen shot 2012-02-28 at 10.19.23 AM.png (16kb) downloaded 4 time(s).
blowlamp
#4 Posted : Tuesday, February 28, 2012 11:05:47 AM(UTC)
blowlamp
I can't make out what you're doing from the pics.
Can you post the file for us to look at?
Martin.
misterrogers
#5 Posted : Tuesday, February 28, 2012 11:30:12 AM(UTC)
misterrogers
Okay here's the panel in question.
paneltoblendedge.sfx (74kb) downloaded 4 time(s).
rockyroad_us
#6 Posted : Tuesday, February 28, 2012 5:34:36 PM(UTC)
rockyroad_us
I would redo the profile. There's a small kink on the upper left side which is too small to detect. Another way to check this problem is to check the draft angle. :eek:
rockyroad_us
#7 Posted : Tuesday, February 28, 2012 5:59:37 PM(UTC)
rockyroad_us
Also, with your original profile make sure you have continuity especially with the slopes at the meeting curves. When I broke the solid to lines I get a lot of slopes going at different directions.
misterrogers
#8 Posted : Tuesday, February 28, 2012 8:28:00 PM(UTC)
misterrogers
Thanks, I will redo the curves. The profile was given to me in an adobe illustrator file which I imported into shark and extruded. I probably should have redrawn it and thus mitigated any of those wonky errors..
