misterrogers
#1 Posted : Tuesday, November 10, 2009 8:49:56 AM(UTC)
misterrogers
I know there's a way to do this in shark, but I can't figure out how to "import?" a bitmap image to use as a decal. I read the manual and see that this is possible, but when I put the bmp in the correct folder, I don't see it in the render library. Anyone know the correct procedure?
Thanks!
#2 Posted : Tuesday, November 10, 2009 2:58:35 PM(UTC)
I'm not sure how it's supposed to work (after 10 years) - but I always open one of the pre-made textures .. then change it to what I want in photoshop and save it back to exactly where I found it. Only that way do I know the size, format and name all line up
Not the best answer, but it might move you forward
Agree the manual is pretty lacking in this regard
misterrogers
#3 Posted : Wednesday, November 11, 2009 9:00:09 PM(UTC)
misterrogers
Thanks JOL. I will attempt that route.
