Art
#1 Posted : Wednesday, May 14, 2008 1:11:25 PM(UTC)
Art
When I use the "Deep Select" cursor to explode a curve on a solid in a group it does not work.
When I try to offset a face of a solid within a group, it does not work.
Is it supposed to? If not, what is it good for?
Art
MacIntel/Shark
#2 Posted : Sunday, June 1, 2008 2:55:51 PM(UTC)
>> Is it supposed to?
No, but those tools should be corrected to recognize edges/faces within groups independent of deep select.
We orginally put it in to select objects within groups. We're gradually extending its functionality. Things that deep select can do
--modify objects position/attributes within a group
--automtically turns on/off points &handles for splines
--pick faces of a solid and change color
--pick faces of a solid and remove them by hitting the delete key
