Mogal
#1 Posted : Sunday, August 14, 2011 9:38:39 AM(UTC)
Mogal
Hello,
I'd like to get some help please.
I'd like to have a continous rope wrapped around a rectangle.
(pictures attached - the inside rectangle)
I've tried a couple different ways, but can't seem to get it.
I've created a length of rope, and stiched it to one piece,
then tried to bend it, but its not working like I thought it would...
I'm new to VC and in the learning phase.
Can someone help explain how this would be done?
P.S. Is there a way to get the gripper to grip a different location of the selected object? ie: the center of a circle insted of the circumference?
Mogal attached the following image(s):
Rope Plaque.jpg (21kb) downloaded 4 time(s).
Rope Plaque 2.jpg (32kb) downloaded 4 time(s).
Mogal
#2 Posted : Sunday, August 14, 2011 7:05:48 PM(UTC)
Mogal
Well, I'm a little upset.
I actually had a bend that was acceptable, and pieced a rope frame together as needed.
As I went to save my MAJOR acomplishment :p didn't VC crash, and corrupt my project :mad:
Now I have to start over again. err.
Well, I can not seem to get the bend tool to operate correctly... and when I do, I get this: (pic attached)
The gripper is all messed up.
I could really use some help :confused:
Rope Plaque 3.jpg (28kb) downloaded 4 time(s).
Mogal
#3 Posted : Monday, August 15, 2011 8:15:54 AM(UTC)
Mogal
So why would the bend tool work sometimes and not others?
Is there something I'm missing?
Here are some of the errors I'm getting:
Warping created a bad body:Bend_xxx and
The bending configuration will compress/invalidate the entity:Bend_xxx
The biggest thing I don't understand, is that I *HAVE* gotten a perfect bend out of it.
but 99% of the time I get the errors...
rockyroad_us
#4 Posted : Monday, August 15, 2011 1:56:58 PM(UTC)
rockyroad_us
upload your VC file.
Mogal
#5 Posted : Monday, August 15, 2011 4:54:04 PM(UTC)
Mogal
I can't upload the VC3 file(zipped or not) I get the error:
Your submission could not be processed because a security token was missing.
I can upload pics though... (note the gripper)
One thing I have discovered, is that I can consistantly bend the object from the top view, but only once and only on the X axis. I'll get errors from any other axis.
After the rope is bent, the gripper becomes unustable on it, but on other objects, the gripper is fine.
Rope Plaque 5.jpg (26kb) downloaded 4 time(s).
#6 Posted : Monday, August 15, 2011 5:52:54 PM(UTC)
If what you need is something like this:
[ATTACH]3983[/ATTACH]
then use the extrude along path command and use the twist variable to set the desirable rope alike shape.
a video that can be useful is this
http://www.csi-concepts.com/Demo/videos/CSnap.mp4
Just use three circles instead the hexagon, consider that the bend radius should't be smaller that the total diameter of the shape (i dont know if viacad have this feature, i am in shark)
hope this help
MacOSX Sequoia 15.7.7
Mogal
#7 Posted : Monday, August 15, 2011 7:49:12 PM(UTC)
Mogal
Ah Dang it :mad:
But first and formost THANK YOU Luis! :D
It took me awhile, but I got it!
and (again) just as I clicked to save it, BOOM! VC stopped responding :(
I'm running Windows 7 64bit.
I just set VC to run in WinXP SP3 compatibility mode with admin rights... hopefully that will calm things down some...
WOOT! time to go try this again!
chipmaker2
#8 Posted : Monday, August 15, 2011 8:47:15 PM(UTC)
chipmaker2
Mogal
When making stuff that makes the program misbehave, crashes, long wait times after rotating, etc etc. It's better to make a new file IE "save as" every time you make progress so you don't lose work. Under file/preferences/filing check the "auto save" box and set the options to something you can live with.
Chuck
Mogal
#9 Posted : Monday, August 15, 2011 9:58:30 PM(UTC)
Mogal
Thanks Chuck, I now have autosave enabled.
I do get a little frustrated learning this(or any new program) to its fullest potential,
but I must say, the more I learn what this program does, the more impressed I am with its capabilities.
Its finding the 'right' way to do it thats my biggest problem ;)
More questions will be coming as I make headway! :D
Chris
FYI, this is what I'm working towards:
Prelude to Action.jpg (42kb) downloaded 4 time(s).
Mogal
#10 Posted : Saturday, November 19, 2011 7:18:34 PM(UTC)
Mogal
Well, its been a little while, but I like to here back from people when they get thier task done.
So here is my task... it turned out GREAT!
Thanks to everyone for helping me out!
Prelude to Action 01.jpg (101kb) downloaded 5 time(s).
Prelude to Action 03.jpg (92kb) downloaded 5 time(s).
Prelude to Action 04.jpg (75kb) downloaded 5 time(s).
Prelude to Action 05.jpg (77kb) downloaded 5 time(s).
Prelude to Action 06.jpg (78kb) downloaded 5 time(s).
Trfsrfr
#11 Posted : Sunday, November 20, 2011 11:08:17 AM(UTC)
Trfsrfr
That looks awesome!
Redss
#12 Posted : Sunday, November 20, 2011 5:53:32 PM(UTC)
Redss
Mogal
Like you said that is great
Jean-Francois Jacques
#13 Posted : Tuesday, November 22, 2011 10:33:55 AM(UTC)
Canada
For understand ..you did a CNC from a Shark geometry??
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
la mouche
#14 Posted : Wednesday, November 23, 2011 5:44:41 AM(UTC)
la mouche
hello,
same question.
Antoine
Mogal
#15 Posted : Wednesday, November 23, 2011 10:03:38 AM(UTC)
Mogal
Yes, I have ViaCad 8 though.
I use Vectric VCarve Pro software, but there is no 3D design capabilities with it, so I made the 3D rope with ViaCad,
used Cut3D to generate the toolpaths and imported it into VCarve pro, where I could finish my toolpaths.
So, yes I made the rope with Viacad, and then I CNC'd it.
sorry, I guess I could have made my pictures a little larger...
You guys have never done this? :confused:
I've been having fun with ViaCad! I have some bolts that I was working on as well...
as soon as I get the material to make it, I will be CNCing some more!
Half rope.jpg (19kb) downloaded 4 time(s).
Half rope 2.jpg (20kb) downloaded 4 time(s).
blowlamp
#16 Posted : Wednesday, November 23, 2011 11:14:04 AM(UTC)
blowlamp
Ditto, Mogal.
I've been using ViaCAD along with CamBam for quite a while now, for both 2d and 3d work.
In fact it's such a good combination, that it's popular with other CamBam users too.
Martin.
#17 Posted : Wednesday, November 23, 2011 10:37:59 PM(UTC)
I use shark for all my modeling, then past in to a cam software for various process:
sheet metal cut on cnc plasma, CNC turret, waterjet, cnc milling, profiling and routing.
#18 Posted : Thursday, December 1, 2011 12:43:23 PM(UTC)
Was thanked: 117 time(s) in 78 post(s)
The mp4 was great. It reminds me of some things I want to try in VCP 7
