hi there...
im a new user of Viacad 2d/3d, and im trying real hard to learn how to use nurbs (so much years of polygon modeling :p). Even after i read the manual, im still lost sometimes, so im asking for help.
1 - if i project a curve to a surface, with the option to embed the curve into the surface, can i delete the projected part, leaving a hole in place? (see image question1)
2- im trying to model the shape as seen in image 2 (in the left a right view, showing the profile i used). How can i made that parte with thickness (solid) to use booleans later? In the way i did (revolving a profile), i cant use thickness enough to my needs, as it gives me errors.... i tried skin solid, but it gives me a rounded surface, and i need those sharp corners...
sorry if the question seens stupid, but im new to nurbs, and cant figure out everything just by the manual. Also, forgive my bad english, but im brazilian :p
thanks in advance
mvotre attached the following image(s):
![](/Themes/punchcad2/icon_file.gif)
(34kb) downloaded 5 time(s).![](/Themes/punchcad2/icon_file.gif)
(98kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
