Solid Modeling
Flame Model, right tool? (#2953)
Ok,
So I need to model the attached image. Is Shark/ViaCAD even the right tool to model this? Is it going to be like using a dull butter knife to peel an apple (it can be done, but it easier with a sharp knife!)
Should I be looking at another CAd/3D package?
WIP
Let's see if I keep all my hair... (and don't pull it out trying to build this!)
I advise you to use a polyedric modeler to create organic models.
Cinema4D
Hexagon
Modo
Cheetah
Blender
ZBrush
Carrara
Lightwave
XSI
here a link to a forum:
http://forums.polyloop.net/ Antoine
Right, but will I be able to import something that complex and make a solid from it.....that is the question....?
Hello,
No problem to convert the mesh into a solid.
Warning!
1 - if the mesh is heavy ==> composed of many facets, the conversion amount will be very long.
2 - check that the mesh has no holes.
see my demo:
http://screencast.com/t/YjU3MzY3NDk and demo with V.7 ===> fantastic with gripper tool
http://screencast.com/t/MTBiZWRjMGY [COLOR="Red"]Tim?[/COLOR]
it would be impressive if you could add in the future, polyedrics tools as: smoothing algorithm :eek:
my camel have .... just ... accident:p
Cordialy
Antoine
Antoine, I gave it a go in Shark last night, but as you suggested, I am building in C4d and will import into Shark ( a small test 1st!). I just don't have enough control in Shark (or expertise). Thanks for your examples! Norbert
Solid Modeling
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
