norbertsf
#1 Posted : Tuesday, February 2, 2010 12:19:49 PM(UTC)
norbertsf
Ok,
So I need to model the attached image. Is Shark/ViaCAD even the right tool to model this? Is it going to be like using a dull butter knife to peel an apple (it can be done, but it easier with a sharp knife!)
Should I be looking at another CAd/3D package?
UserPostedImage
norbertsf
#2 Posted : Tuesday, February 2, 2010 9:48:37 PM(UTC)
norbertsf
WIP
Let's see if I keep all my hair... (and don't pull it out trying to build this!)
UserPostedImage
la mouche
#3 Posted : Wednesday, February 3, 2010 2:43:09 AM(UTC)
la mouche
I advise you to use a polyedric modeler to create organic models.
Cinema4D
Hexagon
Modo
Cheetah
Blender
ZBrush
Carrara
Lightwave
XSI
here a link to a forum:
http://forums.polyloop.net/
Antoine
norbertsf
#4 Posted : Wednesday, February 3, 2010 8:28:40 AM(UTC)
norbertsf
Right, but will I be able to import something that complex and make a solid from it.....that is the question....?
la mouche
#5 Posted : Wednesday, February 3, 2010 9:51:09 AM(UTC)
la mouche
Hello,
No problem to convert the mesh into a solid.
Warning!
1 - if the mesh is heavy ==> composed of many facets, the conversion amount will be very long.
2 - check that the mesh has no holes.
see my demo:
http://screencast.com/t/YjU3MzY3NDk
and demo with V.7 ===> fantastic with gripper tool
http://screencast.com/t/MTBiZWRjMGY
[COLOR="Red"]Tim?[/COLOR]
it would be impressive if you could add in the future, polyedrics tools as: smoothing algorithm :eek:
my camel have .... just ... accident:p
Cordialy
Antoine
norbertsf
#6 Posted : Wednesday, February 3, 2010 2:47:32 PM(UTC)
norbertsf
Antoine,
I gave it a go in Shark last night, but as you suggested, I am building in C4d and will import into Shark ( a small test 1st!). I just don't have enough control in Shark (or expertise).
Thanks for your examples!
Norbert
