Shark beta build 949 - still some issues here (#3400)
Just to be clear - here are my issues with Mac beta build 949 : - display last image broken - navigator is empty on startup and on app change back to Shark - scale object for a subsequent time using the 'click, enter' method fails. Try again and the scale factors reset to 1,1,1 - some OpenGL flakiness with objects flickering off and on - sporadic can't seem to repeat - tool icons should change to select arrow when above the drawing window topbar - cannot nudge an object with the cursor over it (gripper on). Eg draw a cube by 3 points. Go to Select tool and leave the cursor over the cube such that it says 'origin' (or one of the gripper icons shows like the hand withe the blue arrow). Now nudge - nothing moves .. why ?
and the render smudge - please can we get rid of it ?
every time I do a rendering using the "user defined" render preset, I get a graduated smudge at the top inch of my screen
interestingly, there is no smudge when using any of the other - less used and less useful presets
(216kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
- display last image broken Fixed in 950 - navigator is empty on startup and on app change back to Shark On startup or new file is fixed in 950. Change back have not repeated yet. - cannot nudge an object with the cursor over it (gripper on). Eg draw a cube by 3 points. Go to Select tool and leave the cursor over the cube such that it says 'origin' (or one of the gripper icons shows like the hand withe the blue arrow). Now nudge - nothing moves .. why ?
Repeats here,looking into. Looks like the origin is taking the nudge.
- cannot nudge an object with the cursor over it (gripper on). Eg draw a cube by 3 points. Go to Select tool and leave the cursor over the cube such that it says 'origin' (or one of the gripper icons shows like the hand withe the blue arrow). Fixed in 950. FYI, you can also nudge gripper symbols (tx,ty,tz,rx,ry,rz,sx,sy,sz). tx,ty,tz uses nudge distance in prefs rx,ry,rz uses 5 degrees sx,sy,sz scales up by nudge distance Tim
