#1 Posted : Sunday, January 30, 2011 10:15:46 AM(UTC)
Extend surf / offset surf tools
Tim ... are you using the same value variable for both tools ?
I'm alternating between these 2 tools and would expect to be able to set offset to -10 mm and extend to +15 mm and have these values stick
Instead, when I go from the offset tool (set to -10mm) to the extend surf tool .. I find that the value has changed from +15mm to -10mm
This is a simple workflow issue - but would save me lots of time as I have 100+ objects to offset and then extend (by these different values)
Hope that made some sense
#2 Posted : Monday, January 31, 2011 11:31:55 AM(UTC)
Yes, fixed in 961.
#3 Posted : Monday, January 31, 2011 5:09:11 PM(UTC)
Thank you Tim !!
