#1 Posted : Sunday, April 8, 2007 5:00:56 PM(UTC)
I'd like to see an addition to the min distance tool
To sample several points along both curves, picking out max as well as min distance .. and giving several relational distances inbetween
This would help users set up constantly changing relationships between splines more easily
Also, I'd like to see inflection points of splines picked out by a little arrow (where a spline changes from -ve to +ve etc) in this and the curve plot tool)
nabed
#2 Posted : Monday, April 9, 2007 2:41:53 PM(UTC)
nabed
In addition, as already mention several times in the old forums, an equivalent function to the "keep intersection solid?"-option of the check intersection command would be very appreciated.
Why can't we keep the black line representing the minimum distance as line object?
Just a suggestion.
Ciao, Norbert
