Albatrossflyer
#1 Posted : Thursday, November 13, 2008 12:21:27 PM(UTC)
Albatrossflyer
Is there any way to bump up the DPI from 72 to 300 when I export to JPG in VIACAD 2D/3D????
If not, would exporting to AI format and then doing the JPG conversion in AI work?
nick
#2 Posted : Friday, November 14, 2008 6:38:44 AM(UTC)
nick
Hello
There's no way to up the resolution of the export and it really depends on what type of output you are trying to get out into a graphic format, 2D Dimensioned Drawings or 3D Shaded Models, as to whether exporting to an alternate file format will improve your results.
Perhaps you could post a sample file and I'll take a look at some options for you?
All the best
Nick
Albatrossflyer
#3 Posted : Friday, November 14, 2008 12:11:16 PM(UTC)
Albatrossflyer
unfortunately I need to supply a 300 dpi jpg image.....
nick
#4 Posted : Friday, November 14, 2008 3:23:14 PM(UTC)
nick
If you need a shaded image then I'm afraid you may be out of luck, you could try either printing to .pdf or exporting as .ai but you will get a faceted result albeit at the higher resolution.
Albatrossflyer
#5 Posted : Friday, November 14, 2008 7:28:28 PM(UTC)
Albatrossflyer
the model is a surfaced wireframe. tried both the pdf & ai routes. the resulting images looked like s--t.
#6 Posted : Saturday, November 15, 2008 2:37:11 AM(UTC)
It really needs 'rendering' ??
nick
#7 Posted : Saturday, November 15, 2008 8:12:09 AM(UTC)
nick
Only other possibility I can think of would be to screen grab / export .JPG of model in sections, so instead of zooming the model to fill entire screen, zoom in so that a 1/4 of the model fills the screen and then assemble your collage in Photoshop.
All the best
Nick
NickB
#8 Posted : Saturday, November 15, 2008 1:26:00 PM(UTC)
NickB
Views messages in topic : 501
Why not render to file, then change the resolution in Photoshop or some other image editor. If your on a Mac you can even do this in Preview.
Shark FX 9 build 1143
OS X 9.5
matter.cc
nick
#9 Posted : Saturday, November 15, 2008 4:54:35 PM(UTC)
nick
Hello Nick
I think you might have missed the top post in thread, it's ViaCAD 2D/3D not Shark FX so no Render To File I'm afraid :(
All the best
Nick
#10 Posted : Sunday, November 16, 2008 1:46:49 AM(UTC)
Originally Posted by: nick Go to Quoted Post
to screen grab / export .JPG of model in sections,...... then assemble your collage in Photoshop.
I do this very often.
To me, a screen grab is always a better option than a render, even with Shark FX...
#11 Posted : Sunday, November 16, 2008 5:29:32 AM(UTC)
it's an interesting thought for Tim
perhaps a high resolution jpg screen "grab" is something that could be simulated - I guess by misleading the program into believing it is sending info to a huge screen buffer - but instead sending it to a file to be output via jpg
whether you are a VC or a Shark user, this could be an enormously useful working tool
thoughts ?
