Surface Modeling
Deform to curve just doesn't work right ! (#1397)
Deform to curve just doesn't work right ! Why ? You select a surface .. then you select a constraint curve. Sometimes the face will move .. however, I've literally never had it hit the constraint curve Often, it doesn't move - yet the feature tree says that it's now a 'deform face'
oops .. here's the image
(18kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Hi jol, Is it supposed to work on surfaces? It works OK on faces of solids (shark FX 737 PC), to hit the curve I just need to enter a very large Gain size. - Steve
you're quite right Steve, I am having some success with solid 'faces' and extremely high numbers like 50,000 However, it allows the selection of surfaces .. just like bend and thicken tools do. But the results are rubbish Perhaps it should just not allow you to select surfaces !?
Hi jol, I agree, certainly one for Tim to clarify. - Steve
Fixed in next upload.
(60kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Tim .. that's a HoooooJ thing for me Thanks !
Surface Modeling
